ls1 carb help
ls1 carb help
i thinking of changing my efi to the duel carb with mds electronic ignition because i am a bad tuner and every thing i try leads to the car not running so has any one done this setup in a f body the thing i want to know are the following
1 does the hood clear the carbs ?
2 how do you hook upo the rpm gauge and speed gauges to read when there is no ecu
3 how do i hook up the fuel pump ? direct power ?
4 any other suprizes
thanks for the help joe
