oil pressure sending unit question
Old 10-07-2007, 06:24 PM
The PAT WS6's Avatar
Default oil pressure sending unit question
im gettin rather low pressure. and i noticed that my oil pressure sending unit only feels like there is one (1) wire goin to it... is there supposed to be 2 on the clip thingy or what?
thanks
Old 10-07-2007, 06:45 PM
Restricted User
socmguy's Avatar
I believe it's a two pin connector. If you're seeing your gauge working at all it should be reading correctly unless there's a poor connection. Get out and listen for increased valve train noise. If your motor's making a racket you may need to do some detective work.
Old 10-08-2007, 02:43 AM
i need to knw for sure. my oil pressure is hella low at time.s
Old 10-08-2007, 09:12 AM
Viper's Avatar
Put a mechanical gauge on it to compare; that will tell you if the sending unit is bad.
Old 10-08-2007, 10:51 AM
Restricted User
Zero4488's Avatar
I agree
Old 10-08-2007, 04:32 PM
we hooked a mech. gauge to it and the gauge in the car is slightly off by a few psi so its not an electrial problem, i have the ported ls6 oil pump in the car but when the motor blew it locked up? so maybe it damaged the oil pump? wat do u guys think
