bad exhaust vibration
Old 10-07-2007, 07:52 PM
hokie00 TA's Avatar
Default bad exhaust vibration
just installed pacesetter headers on my 2000 ta and now i have a really bad vibration around 1500 rpm. what would cause this, and what would solve this problem.
Old 10-07-2007, 08:40 PM
hokie00 TA's Avatar
if i do the poly motor mounts would it cause anymore vibration it the car or would it take care of the vibration.
Old 10-07-2007, 08:49 PM
hotrod7687's Avatar
What Y pipe are you running. It could be hitting the floorpan.
Old 10-07-2007, 08:54 PM
02trns_am's Avatar
Yeah check out the pipe and see if its hitting anywhere. Also, the little brace thing that runs under the y pipe was causing alot of noise on mine so I just took it off. You might want to check that out.
Old 10-07-2007, 09:12 PM
hokie00 TA's Avatar
the only time the y pipe bangs the floorboard is under hard acceleration. and for the tunnel brace yea i didnt even put that back on after installing the headers because the beace wouldnt even come close to bolting back up because the y pipe hung to low.
Old 10-08-2007, 04:24 AM
hokie00 TA's Avatar
anyone?
Old 10-08-2007, 11:12 AM
Restricted User
Zero4488's Avatar
just keep looking...cause I have a bad vibration around 1700rpms on the decel...and I just have to try to find out where it's hitting....
Old 10-09-2007, 04:22 AM
hokie00 TA's Avatar
anyone else?
Old 10-09-2007, 04:59 AM
odarabla's Avatar
Originally Posted by hokie00 TA
anyone else?
I am looking for the same problem on my 2002 Z28. Mine shutters on take off. I can feel the vibrations in the floor boards. I just put in Hookers with y-pipe. I think it might be the connections vibrating. I am going to take mine the the muffler shop this weekend and get flanges welded to the pipe!! Hopefully this takes care of that.
Quick Reply: bad exhaust vibration
