What the HELL is going on?!?!?!
today i raced an evo on the freeway...slowed down to about a 30mph roll and hit it from 1st...shifted to 2nd and let off becuase there is a car that switched into my lane...i take it out of gear as i'm braking and when i try to get back into gear i can't because my clutch pedal is stuck to the floor...it stays there for about 10 seconds and slowly comes back to normal...its happened to me about 3-4 times now and its driving me crazy!! any idea what it might be??
the car is pretty much bone stock...stock clutch...i've had it for about 5 months and all i've done is a magnaflow catback, slp lid, amsoil high flow air filter and TB bypass...its a 2000 Z28
Sounds like your master cyliner is on its way out. This problem is almost 99% always a result of failing hydrolics. When you replace it I would also suggest goin ahead with a LS7 clutch upgrade, new slave & possibly a new pilot bearing while your in there. Also you can wrap your hydrolic line on the new master with either some header wrap or some other heat shielding to help keep the fluid from overheating.
http://www.installuniversity.com/ins...sity/index.htm go here then click install documents on the left scroll down and then click Drill Mod with McLeod Master Cylinder Install, or you could use the SEARCH BUTTON AT THE TOP OF YOUR SCREEN
hope this helps
hope this helps
welcome to world of the sh!tty LS6 clutch system. Mine does that too, do it with 415 RWHP....
anyways, go with the LS7 clutch someone correct me if i am wrong, but the LS7 clutch holds up to 500+ RWHP..
Also you fill need the following: New Slave, since your a 00, you will need the new upgrade master cylinder, piolt bearing, TOB
good luck
good luck
