Drilling Lid
I myself still have the AIR since I run cats but pluged the hole of my SLP lid with a plastic grommet and some epoxy which turned out pretty clean looking.
You mean the IAT sensor? Seen posts where they forgot to drill the hole before. Measure the hole on the stock lid, drill it in about the same location, then transfer the grommet/sensor to the new lid.
If you are talking about the adapter for the larger Delphi MAF's I purchased mine through Caspers (a site sponsor). I know there are a few other sponsors on here that sell it also. I thinks it looks better with the adapter on instead of having the sensor in the neck of the lid.
I ordered TWO lids, and both came NOT pre-drilled. Right, he's talking about the IAT sensor with the rubber grommet. Usually, people order a set from GM. But i think they charge somewhere around 30 DOLLARS! Just take ur time, and pull your rubber grommet out of your stock lid. I used a really thin drill to put a hole in it and made several little holes around, then just filed it down with any filer or even sand paper. It took me about 30 mins cuz my drill kept running out of power. But take your time and every now and then see if your Rubber piece fits....
Remove your stock lidbox, and put your clear lid in its place, line it up with the tabs, and just put it up with the MAF (as if your installing it), then just mark where you think is a good spot. Even if your off by a whole inch or 1 1/2 inches, the wire is long enough to spare a few.
Just so you know though, it is an 11/32's hole. Hope that helps.
I'll let you all know how it goes.
same thing happened to me just did exactly what ophee did, just kept using progressively bigger drill bits until i could get the grommet in there....
getting the grommet out of the stock lid was a bitch tho, using soap and water and prying hardcore with a knife finally popped it out....
