Heads and cam Q' ms4, ms3 or trex?
I'm thinking about going H/C soon. I know I'll probably do ls6 heads. I was looking into the Ms4 cam or a trex cam. I love the sound on them. I've also hered that u go through springs constantly and they are only good for top end power. any input on that? what would u guys suggest me get? or should I just go w/ an ms3?will I get better power at lower end? so many Q's....hmmm... thanks for the replies.
Generally the larger cams are top end cams. You will lose a lot of bottom end power. I think you should look into a custom grind that fits your wants/needs perfectly.
You will most likely have to flycut your pistons with a cam of the above sizes with LS6 heads.
