mac oryp
mac oryp
I put on the mac oryp and i have clearence probs between the pipe and the floorboard on the drivers side. At about 3500 rpm it starts vibrating real bad how do I fix.
Re: mac oryp
A few people have posted on here that they adjusted the Y-Pipe so that it was as close to the floor board as they could get it and then cut some heater hose and wedged it between there...at the time I tried mine I didn't have any heater hose...so I tried fuel line and it worked...but I didn't have it in there good enough and it fell out...I also read where some people changed out there motor and tranny mounts for poly mounts...and it helped out a lot too...I'm going to be swapping mine out in about two weeks..I will post if it helps at all.....
Re: mac oryp
With the ball flanges on the Mac headers and Y-pipe, there is a lot of room for adjustment... Did you try loosening everything a bit, pry the pipes down, then re-tighten?
My Mac ORP has lots of clearance....
Tommy
Tommy
