LS6 Intake Read this before trying to change intake.
Everywhere i read be careful not to break the oil pressure sending switch while changing your intake...everyone it seems does it the first time. Well i read it a hundred times and just changed mine and guess what i broke?
For those who might follow me on this i'm going to try and shed some light on this so you don't see the same issues. The problem comes when the rubber hose from the brake booster is disconnected from the brake booster only. You can not reach behind the intake easily to get it off the back so i see three options for the rest of you...
1. Spend the time and attempt to get the hose over the top of the sensor or around the sensor. (Not sure that's possible)
2. Move the intake very slightly forward once the bolts are removed. And then attempt to remove the hose from the back of the intake. (I find this unlikely the first time you do this as well and even when it was off the car that hose was very snug on the intake)
3. Buy the sensor and just flat out no give a sh**t when you do snap it in half. That is in my opinion the best way.
Don't let this stop your install, buy the sensor and plan on changing it. Trust me it is very easy to break. I was forewarned and i broke mine. Now tomorrow i have to find one on a Sunday so that i can put the car back together.
idk.. Ive had my intake off 3 times without a problem... my buddy has had his off at least that many times. and I helped a guy take one off not too long ago without a problem either....... **** happens though..
When I changed my knock sensors mine came off without breaking. Like you stated above you have to work the hose over the sensor while bringing it forward. Some people aren't capable of it or just don't have the patience.
I found it best to buy the oil pressure sending unit socket and place it on the sending unit while removing the intake. If you make sure somebody watches it and doesnt allow it to come off it forces you to avoid breaking the sending unit (because the sending unit gives and will break when pressure is applied to it, whereas the socket wont).
First, take out all the intake bolts you can and use about 1 inch of vacuum hose to hold up the rest of the bolts to where they will clear the heads. Then, all you have to do is reach your hand down the driver's side of the intake and lift the hose over the sensor before you pull the intake. It is easy to tell when you clear the sensor. Simply lift the front of the intake with the throttle body and the rear with the brake hose about 1 inch then pull the intake forward. It really is that easy.
Galen
Galen
Pontiacerator
First, take out all the intake bolts you can and use about 1 inch of vacuum hose to hold up the rest of the bolts to where they will clear the heads. Then, all you have to do is reach your hand down the driver's side of the intake and lift the hose over the sensor before you pull the intake. It is easy to tell when you clear the sensor. Simply lift the front of the intake with the throttle body and the rear with the brake hose about 1 inch then pull the intake forward. It really is that easy. Galen
I found it most helpful to have a second pair of hands gingerly feeding the hose through as I pulled it forward.
ive broken one sending unit out of 5 swaps. the last swap i did i got irritated and wasnt thinkin and broke the unit.
although its a lil difficult use the socket and it wont break off. two sets of hands are good too.
Well now that i have done it and seen it and gotten totally F-ed over by it happening to me i can guarantee it will never ever happen again.
I just think that for the person who is doing it the first time it is still very possible even with warning to break it so you should have the sensor onhand anyways.
Anyways LS6 intake is now installed, except for the getting the back bolts out and the broken sensor it was relatively easy. Seems like a nice power gain too with that mod although i would have to get the car dynoed to be sure but i feel a noticeable difference.
Niuce writeup...I haven't broken mine yet...don't know if that means I'm patient or good at doing it or both but I never seemed to have a problem. I think people just aren't taking their time.
