Should I upgrade injectors for retune?
Hey guys I have a LS1 that was out of my Z28 and put it in a RX7 and I was wondering if I should upgrade my injectors? Here are my mods
Long Tube Headers 1 3/4 to 3" exhaust free flowing
Ported Stock Throttle body, Thinking about porting my maf
Ram Air intake
TSP Torquer v2 Cam 232/234 .595/.598 with 112lsa
Twin Sprocket Timing Chain
LS6 Ported oil pump
4.10 gearing & Aluminum Drive shaft (not sure if it makes a difference)
I am sending my pcm to pcmforless to get tuned and was wondering if I should get larger injectors before I send it off to get tuned. I was thinking somthing around 32lb or the ford SVO 30lb=36lb for chevy? Also what kind of power should I be expecting with this setup.
TIA
Tony
Ram Air intake
LS6 Ported oil pump
TIA
Tony
It cant hurt to upgrade the injectors as you will be reaching the limits of the stock ones. I would think you should be around 400rwhp. You might want to upgrade to an LS6 intake if your motor isn't out of an 01-02 Z28.
