IS IT WORTH MAKING YOUR OWN X or H-pipe?
Thinking about making my own ture dual set-up just trying to come up with some ideas. It seems like I could make the pipes from the collectors back then just cut a hole in the side of the pipes and weld in a h pipe.
i herd that after u make ur daul take spray paint and spray it down the side of each pipe and crank the car up and where ever the paint burn off in the same spot on both pipes is were u should but the h pipe {i herd dont know for a fact}
the H pipe is pretty basic to make...jsut as you describe.
the X takes a bit more work welding, but not much. take 2 90* bends and cut off part of the bend...weld together.
Hpipe sounds better
Xpipe make more power
Hpipe sounds better
