1.125" Hex size AN fitting wrench?
I'm putting an Earl's oil cooler into my C5 and the hose fittings are 1.125". I've been trying to find an AN wrench to fit it and can't. I found a -12 AN which is 1.250", a -10AN which is 1", a -12 AN socket wrench which is 1.188", and a -10 AN socket wrench which is 1.063". I mic'ed the fitting and it is indeed 1.125" across and the instructions, from Earl's specifically state to use a 1 1/8" AN wrench. It also says to use 2 wrenches, one on the fitting the other on the cooler port to keep from twisting the port out. I suppose I could buy 2 adjustable AN wrenches at ~$60 a piece, but was hoping for a suggestion that would keep more change in my pocket. Any ideas?
