wont start on the first try??
Old 10-30-2007, 05:54 PM
chevy0128's Avatar
Default wont start on the first try??
When i start my car if it hasnt been driving within the past couple hours it most the time i will crank it the first time and it will try for like 5-10 seconds or so to start but it wont. The second try it always starts right up ?????what could this be
Old 10-30-2007, 06:16 PM
SSChevy99's Avatar
Fuel Pump?
Old 10-30-2007, 06:18 PM
Toes's Avatar
fuel filter, spark plugs
Old 10-30-2007, 06:24 PM
chevy0128's Avatar
would this be something to worry about?
Old 10-30-2007, 06:25 PM
redchevcam's Avatar
my first question is....what kind of car and setup
Old 10-30-2007, 06:26 PM
simple's Avatar
sounds like fuel pump to me.
no starts on the 1st attempt after it has sat for just a little while is a symptom of a bad fuel pump. this is because it bleeds off all pressure in the fuel lines. this causes hard starts like you describe. i cant remember what its called (plunger maybe?) but there is something in the pump that goes bad causing this issue.
a good "up to par" fuel pump should hold pressure for a long time. it should only bleed off 1 or 2 psi over a matter of hours.
check fuel pressure at the schrader valve on the fuel rail.
also try priming the fuel lines, just turn the key 2 or 3 times to the on position for a few seconds until you hear the pump stop each tim, then try cranking it. might fire up then at then point.
BOA279's Avatar
need more info...
Old 10-30-2007, 06:37 PM
chevy0128's Avatar
this is basicly stock 01 camaro z28 its got the ls1 and just a couple bolt ons...exauhst, air induction, and a 100wet shot installed this friday...thats why i am kind of scared about this
Old 10-30-2007, 11:16 PM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
My car does the same thing. I was attributing it to the fuel system, however, I was looking at the injectors as they have 117K miles on them and may be bleeding down. I haven't had a chance to get to it as of yet.
Old 10-31-2007, 02:24 AM
simple's Avatar
thats another good option, as is the fuel pressure regulator.
but i have to say the most common fuel issue with all 4th gens is the fuel pump itself! but only most common, not thee only.
but you can check the injectors by priming the fuel system (key on) while the fuel rails are unbolted and raised up out of the intake manifold, with the injectors still in the rails. just wait a few if they doesnt leak instantly.
