Explain this induction system to me....
Old 06-17-2003, 04:57 PM
Humanoid's Avatar
Default Explain this induction system to me....
It is obviously not fuel injected. I like the duct tape
It is an air duct after all.
Old 06-17-2003, 05:01 PM
Humanoid's Avatar
Default Re: Explain this induction system to me....
crap just copy and paster the links. I never can attach correctly.
Old 06-17-2003, 06:09 PM
WILWAXU's Avatar
Fix it. You have to link to the picture.. not the page
Looks like a LOOOONNNGGG Fast toys Ram Air Same idea on a different intake setup. Picking up air from the fron valance and ducting it to the intake.
Old 06-17-2003, 07:25 PM
DaleMX's Avatar
Carburated big block with crappy homemade cold air. Wonder if he expects that to stay on during a run. Maybe he NOX'ed (BOOM!) and had to make something quick.
Old 06-17-2003, 11:16 PM
FAST LS1's Avatar
I see what he did, he has both cowl indution and ram air like a fast toys system. You can see the metal ducting in the second pic down by the air dam. Looks like he's just go it over a 4 barrel carb though
Old 06-18-2003, 10:04 AM
WILWAXU's Avatar
Looks to me like a good way to get lots of air to the carb without using a big scoop on the hood.
Old 06-18-2003, 10:38 AM
waverider's Avatar
Looks like something a ricer would have.
Old 06-18-2003, 12:35 PM
TheDogofWar's Avatar
Don't think it's cowl induction at all but it is like the FTRA. Just has to work a bit different for the carb.
I imagine is a was quick rig to get the job done.
I wish I could see the center section of the cowl, I bet he had to cut it to make it fit. have to be running a magnetic crank trigger ignition too.
Bad **** ride!
Old 06-18-2003, 06:57 PM
kp
kp's Avatar
Its just a ftra type airbox for a carb, you can see where the carb stud is. I bet whatever class he is running in cant use a big forward facing scoop. That big block looks like a tight fit :/
