Rear O2 Sims
Rear O2 Sims
I have a TD set up with LT's and am throwing 3 codes. EGR, and 2 02 sensor codes. so my question is, if i get rear O2 simulators, will it take off the codes? and are their any draw backs to the O2 sims?
Ah, thanks, i know it wont change the EGR, but i figure the less N/R's showing for inspection the better. how many miles can you get outta O2 sims? inspection is going to be a bitch im afraid cause of the sniffer.
Sims work for some cars, but will not for others. Sims can fail (do a search). Your best bet is to tune them out. If you don't have tuner access, you can trick them. See threads below:
http://www.srtforums.com/forums/showthread.php?t=93604
http://forums.evolutionm.net/showthread.php?t=114931
http://www.k-series.com/forum/showth...ght=mechanical
no cats..
reason i said something about the 02's in the rear was because i was told even if you tune them out the still show up not ready on the obdII machine. so i figured if i get 02 sims in the rear thats one less n/r thats going to show up.
