Msd coil install failure..
After Coil Install car only hits on driver side cylinders ... What did i do... Feel like a retard .. This is a simple plug and play install........ Anyone encounter this problem?????
98 ls1 trans am
Car ran perfect before install...
98 ls1 trans am
I hate to say it, but you wasted your money on those... Just paint the stockers..... More reliable. Plus they really dont give you any HP. I would pull them off, and get your money back.
Check your INJ-1 and INJ-2 fuses, maybe you shorted the batt+ wire on the harness during the installation.
And next time disconnect your battery whenever working on the electrical system.
Issue was in one of the coils causing the inj 2 fuse to blow replaced coil problem fixed...
Cant really see much difference in power, feels a lil different... but does have quicker throttle response...
Thanks to all that responded
