X Pipe Or Staight Pipes
Im planing on getting my headers and exhaust but not sure what would give me the most power for a having just bolt ons. Not really concerned about the sound just overall power.
An x-pipe setup will always make more power, no matter what your setup. That is because it provides scavenging as well as pressure equalization.
Tech Resident
H-pipe, baby. Sounds way better than straight pipes or an X-pipe and provides more power down low. Less rasp, less interior resonance, more power down low = the way to go for a daily driver.
This is someone who doesnt even have duals giving advice, lets remember. And besides, if youre concerned about power, its top end power that matters.
Tech Resident
What does that have to do with knowing that TD's are like? I WANT TD's because I know what they do. I've put a lot of time into researching TD's because I want them. I'm sure I know more about TD's than some people with them. What's your point?
He stated "OVERALL." The only advantage of an X-pipe is top end power. An H-pipe is better for the other reasons, making it IMO the better choice OVERALL.
An X-pipe sounds like ***. H-pipes are better for a daily driven car. They sound better, produce less rasp and interior resonance and give more power in the usable powerband. An H-pipe will still produce more power over straight pipes, it'll just sacrifice a few peak horsepower compared to an X-pipe.
A Flowmaster D-port merge will produce better gains than an H-pipe up top without sacrificing the sound quality and low end that an X-pipe gives up. That's the way I'd go if I were doing it.
Part FLO-15932
1) you only speak from what you have read online and you have no experience with either setup.
2) you cant say one exhaust sounds better then another, its PURE preference. I like X's better.
3) An x pipe makes more power where it matters, up top. And its not like you'd even be able to notice some huge "loss of low end" that you keep making it sound like.
Youre just an H pipe nutswinger bc of all youve read online and clips youve heard.
The loss of low end isnt ****, an x will gain all over over straight pipe and the top end power its what its all about. And you cant say one exhaust sounds better then another and expect everyone to agree with you.
The only good thing about an H pipe (besides it being your preferred sound) is that they are easier to fit under our cars.
Why do you still not have your duals on yet oh learned professor of teh mighty h-pipe duals?
And like i said before, if yo uask me, the X's soubd better, so dont try to use sound as another benefit of the H.
H = low end (which choco's slow stock car apparently so desperately needs to get to the speed limit in daily driver traffic )
X = top end. I dont have any problems daily driving my "top end" setup, and it lays down more power and higher mph's
I just switched from from an x to an h, because the x was a bit more raspy than I cared for... I have to say the car feels alot better down low & even more so in the midrange.. Couldn't really tell a difference up top vs the x.. The sound is alot more refined & clear with the h as well, I'm happy with the switch. Here's a pic of what I went with, all welded of course not clamped & the mufflers are the delta force race 40 series.. I'm running 3" off the headers into the h & then reduced down to 2.5 at the mufflers for a bit more clearance since I'm lowered.. The case size on the muffers are 3x8x8.5".
-Mike
-Mike
Yep, your right, x-pipes sound awful Just listen to the clip in my SIG to see how shitty my car sounds with an x-pipe setup
To the OP, you will make more power with an x over straight pipes. When it comes to X vs H, it's gonna come down to personal preference. I went from an ORY setup with an open cutout to my true duals/x-pipe/single chamber setup. I gained down low, through the mid-range, and felt an increase in throttle response, but the top-end felt unchanged according to my butt-o-meter.
The general rule of thumb for X vs H is that the X will sound a bit more raw, while providing higher peak power. The H will sound smoother, and provide a bit more down low. To each his own
Wow, I didn't realize you had to have the mod to know what it does. All these theoretical Physicists must be dumber than fry cooks.
Part FLO-15932
Part FLO-15932
You keep my day going, by getting pissy about non sense
Im getting ready to throw my X on and Im pretty excited. I figure that in the future if I feel the need to change over to an H setup, then Ill take that route. But as for now, my vote goes towards the X pipe
There is no best for all set up, every combo will react differently to different mods.
Also, you guys running X pipes with restrictive exhaust systems have waisted your money. It takes a race style high flowing exhaust system to take full advantage of the scavenging affect of an X pipe.
The same goes for those old school guys running header mounted crank case evac systems. If your running a restrictive muffler then it probably wont work and may cause more issues than it solves.
