I want to buy a 2 step
Old 11-22-2007, 09:27 AM
N2RACINGLS1's's Avatar
Default I want to buy a 2 step
Hey all,
I need some help on what type of two step to buy. I have a rossler built 400 with T-brake that I have only used about three times and I would like to buy a two-step to use with the T-brake.
What kind do I need to get for my LS1?
Thats for the help!
Old 11-22-2007, 09:36 AM
Top Fuel's Avatar
Get the Lingenfelter one. you cut one wire, plug in the coil pack connectors, find a place for the box and you're done.
Steve
Old 11-22-2007, 02:08 PM
Any other feedback?
Old 11-22-2007, 02:11 PM
djsanchez2's Avatar
I would say harlan but he doesn't make em' anymore. I do however like the design of the Ling. 2step, i looked at it recently. I'm a M6 and plan on picking one up w/ my 9" and slicks before the summer.
MSD makes a 2-step but it would be alot more work to hook-up. Should work the same though. I believe it only comes with the lil box abd a few RPM pills. If you think about it, it's like paying an extra 100 for a pre-made wiring harness, when you get the Ling. 2-step hahaha
Old 11-22-2007, 05:46 PM
Where can I find out info on the Lingerfelter 2 two?
Old 11-22-2007, 06:42 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
http://www.lingenfelter.com/store/c163.html
Old 11-23-2007, 06:13 AM
Thanks that looks like a pretty good device. I will get it order on Monday!
Old 11-23-2007, 06:14 AM
Top Fuel: Is this the one you went with?
Old 11-23-2007, 07:15 AM
01FbTaWs6's Avatar
this looks like its a sick setup! Going to have to look into one of them also when i get the 9 inch.
Old 11-23-2007, 07:31 PM
Top Fuel's Avatar
yes, it works great
Old 11-23-2007, 11:48 PM
deejaydaze's Avatar
Says may not work with MSD coils....
anyone installed one with MSD?
Old 11-24-2007, 05:22 PM
bad6as's Avatar
i never knew they made one, how to you get it to hit the 2 step, in some videos i set people tap the throttle then go wot and it goes to the launch rpm, but how does it know to stop the launch rpm
Old 11-25-2007, 01:40 PM
Based on what I read so far I quess I wire it into my trans brake switch and when the trans brake is switched on the two step works until I release the switch is that correct?
Old 11-25-2007, 02:45 PM
OWN3D BY MY PROF!
That's for an auto though. There's always all sorts of wiring threads regarding manuals though and usually each one is a little different.
Old 11-25-2007, 03:12 PM
djsanchez2's Avatar
The manual is set up with the clutch or lineloc as the on/off switch. When they are active so is the 2-step, when they are released so is the 2-step rev limiter.
Old 11-25-2007, 07:23 PM
bad6as's Avatar
i see so when the clutch is released the to step does not work, when it is pressed in it does, but what if you stay wot when you shift
Old 11-25-2007, 08:50 PM
deejaydaze's Avatar
You just opened up a can of worms...........ahahhhahha
Old 11-25-2007, 08:57 PM
Tainted's Avatar
so how does it work on an auto car? I've been looking into one but when it comes to wiring im well, an idiot and it may be a bit intimidating to me if its gonna require a lot of wires n splicing.
Old 11-25-2007, 09:04 PM
deejaydaze's Avatar
what's the difference if you gotta splice 40 wires or 2?
They are all color coded and there is a wealth of info on this site and others.
Try something new man! It's how you learn!
Old 11-25-2007, 09:06 PM
Tainted's Avatar
lol I'll end up splicing it to my fog lights or something. wires and me just dont mix. simplicity as far as wiring is how I'd have to go. I've wondered about that kit for a while now and since the OP started the thread, may as well get some info from it
