vaccum pump for normal driving?
Can you use a vaccum pump like one from moroso for just driving around town?
http://www.moroso.com/catalog/catego...?catcode=17200
removed the pcv system when the new motor went in. Just wanting to see if it will help with keeping the intake as dry as possible. have a catch can and breathers just trying to see if it will help in getting that last bit of oil out of intake.
LS1TECH Sponsor
I would not suggest it on a vehicle that see's lots of street or road trip miles. We take a road trip every year and this year had a customer that was running this pump and it failed and locked up while on the trip.
electric air pumps are garbage compared to a belt driven vacuum pump. Its a waste of time basically. (2-3" max vacuum @ rpm)
There is no reason you cant run one on the street. They standardly need to pull some oil mist or small amounts of oil through the pump (from the valve cover or whereever you plumb it). This is what lubricates the pump. You would then just drain the small amounts of oil in the catch/breather can every once in awhile.
I run a GZ motorsports pump setup on my own and customers cars.
LS1TECH Sponsor
This setup has been proven to reduce oil problems with the Turbo Buick crowd. Most likely the electric vacuum pump setup will not make more HP but it will help keeps things much cleaner esp. with FI setups.
http://www.turbobuick.com/forums/gen...ght=Racetronix
http://www.turbobuick.com/forums/eng...ght=Racetronix
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Your car should have come with one from the factory. The Turbo Buick did not come with one. They are all using smog / air pumps used in all types of GM vehicles including LT1 and LS1 cars. We list the part numbers in our ad as well as all sorts of them for sale on eBay.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
The 3 pumps GM uses are shown in our ad.
__________________
>WEB SITE<
>WEB SITE<
