After air removal
Old 11-24-2007, 07:40 PM
Dex
Dex's Avatar
Default After air removal
I finally disconnected my air system and it got rid of all if the backfiring and crackling that my exhaust used to do which was so imbarassing. I'm hoping it improves my gas mileage i was getting 14mpg before i removed it.
The air system is garbage
Old 11-25-2007, 05:27 PM
Black99CamaroSS's Avatar
Mine has been gone since my header install. It really cleans up the engine bay. What block off plates did you use?
Old 11-25-2007, 06:11 PM
Soul TKR's Avatar
I'm getting rid of my AIR and EGR right now... got the race style intake manifold and LT's
Old 11-26-2007, 07:47 PM
Dex
Dex's Avatar
The WS6 store plates only problem was the drivers side i had to double the gaskets because the bolts were to long to tighten it. I cant wait to get headers
Old 11-26-2007, 07:53 PM
1meantransam's Avatar
did mine to clean it up, used thunderracing block off plates
Old 11-27-2007, 07:16 PM
slowandrichws6's Avatar
i heard that that is a good way to reduce weight also. does anyone know how much the Air system weighs?
Old 11-27-2007, 07:24 PM
Titanws6's Avatar
Yeah just took off both AIR & EGR systems and the all crap must weigh between 10-12lbs. Not too bad removing, just a little time.
Old 11-27-2007, 08:28 PM
green28's Avatar
I never weighed mine, but recently removed them when I swaped to an LS6 intake and if nothing else it does make the engine bay look much cleaner. I think Titanws6 is about right though, somewhere in that range.
Old 11-27-2007, 08:44 PM
Soul Crusher's Avatar
How does this stuff go over with the emissions people?
I'm in Vancouver (canada) but I believe we use the same standards as california...
Old 11-27-2007, 11:32 PM
RE AND CHERYL's Avatar
Removing the AIR system is not going to change your fuel economy at all. The system only runs for about 3-5 minutes when the car first starts up to raise temps in the cats faster.
Re'
