Do I NEED a tune?
Old 11-26-2007, 03:09 AM
RWDCelicadude's Avatar
Default Do I NEED a tune?
Will I need to get a tune with long tubes, intake, underdrive pulley, and lightweight flywheel? I'm assuming the underdrive pulley and flywheel won't change anything and I don't plan on doing anything else performance related for a while. So do I need a tune to not damage anything, or is it just suggested for gas mileage/power, or is this not even enough to bother with? Thanks in advance for any advice.
Old 11-26-2007, 03:31 AM
g-ryde1's Avatar
definitely suggested, a tune will completely optimize your performance.
If you dont it will not damage anything.
Old 11-26-2007, 06:06 AM
waldershrek's Avatar
In short......yes you will.
Old 11-26-2007, 06:12 AM
robertbartsch's Avatar
NOt needed.
Old 11-26-2007, 09:36 AM
sroach20's Avatar
it'll be okay till you put a cam in.
Old 11-26-2007, 06:38 PM
King Nothing's Avatar
all that without the LT's nope you don't HAVE to but it's neevr a bad thing. now when you get LT's and remove those cats, yeah you will need a tune pretty quick depending on your drivin habits
Old 11-26-2007, 06:45 PM
transamwes's Avatar
dont listen to king nothing cuz he know's nothing. lol. i just put my lt's in and i drive the s**t out of my car and its fine. i am thinking about getting one but only for the hp gains.
Old 11-26-2007, 07:06 PM
don't listen to wes cause he's a moron who spends his time buyin toothless hookers on south 9th street did you pull your cats off after the install *****?
Old 11-26-2007, 08:00 PM
1meantransam's Avatar
i did full bolt ons, then got the tune. gained a great bit of power
Old 11-27-2007, 06:37 PM
transamwes's Avatar
hell ya the toothless ones give the best head also the cats and stock y pipe were the first things i took off to install the headers cuz it would be impossible to leave them anywhere close to their stock location with lt's. . .duh
Old 11-27-2007, 06:43 PM
Red 01SS's Avatar
You dont NEED a tune. I ran bolt-on's, stall, exhaust and didnt get a tune untill after H/C. The car ran just fine, 12.28@112.4x with no tune
Old 11-27-2007, 06:49 PM
Fb0dy0nly's Avatar
agreed , tune after Heads/Cam unless you plan on never installing these things, then sure, get one, it will help gain some horses and the engine will thank you.
Old 11-27-2007, 07:10 PM
Grimes's Avatar
you don't need one, but to maximize the benefit of your mods, you should get one
Old 11-27-2007, 07:16 PM
i meant did you leave them off after you put the LT's on you jackass
Old 11-27-2007, 08:16 PM
LTLRDSS's Avatar
not to hijack but I’m doing lt’s on my car right now and I’m not going to run rear o2's, will the car run right or will it run really rough. and yes i will do a tune later
Old 11-27-2007, 09:56 PM
RedRocketZ28's Avatar
Car will run fine. Rear O2's just tell you if the cats are working correctly. You will have an SES light but will not hurt anything. That's what I am doing right now. Haven't gotten the codes tuned out.
Old 11-27-2007, 10:46 PM
transamwes's Avatar
yup left mine off unplugged rear o2's drove to the exhaust shop with open headers and had a custom ory welded in. . . car runs fine without the rear o2's
Old 11-28-2007, 10:27 AM
LTLRDSS's Avatar
ok so it wont run rich or lean
Old 11-28-2007, 10:36 AM
TORK?'s Avatar
Alot of places will do retunes for a reduced rate or even free if you do it once. Maybe find a place like that and take advantage of it through every step
Old 11-28-2007, 01:00 PM
SSkillz's Avatar
you dont really need a tune yet! Just with hearders duals and a pt4400 stall i was runing 7.8's on stock tune
