Double Roller + Underdrive Pulley = Help
Old 11-28-2007, 07:32 PM
00Formula00's Avatar
Default Double Roller + Underdrive Pulley = Help
Hey,
I have had the pulley/double roller timing chain set up for about 3k miles and now the belt is starting to walk off of the "track" (right word?). I searched for this problem and everyone was saying the the older pullies werent made to fit with a doube roller, but they modified them to work, and the ones that could work had a stamp on them? I looked and couldn't find the stamp on my pulley, but it is fairly new (I got it in June). So do you think I have to get the Pulley machined down to fit with the chain OR can I do a Katech Belt Tensioner pulley to solve the problem.... THANKS
-Rob
Old 11-28-2007, 09:41 PM
99Bluz28's Avatar
Hi 00Formula00,
The only problems I know of are with the UD pulleys for the corvette with double chains. If the belt/pulley alignment was good before, it still should be good unless the pulley moved.
Old 11-28-2007, 10:30 PM
So are you saying you think that the bolt has backed out?
Old 11-28-2007, 11:01 PM
99Bluz28's Avatar
Yep! That's it.
Old 11-28-2007, 11:16 PM
quiet_storm98's Avatar
i remember seeing alot of places mention that some ud pulleys dont work with double rollers and certain oil pumps without machining them a little to fit...what type of pulley do you have?
Old 11-28-2007, 11:42 PM
Ya, that's what I was reading I am running the ASP, which if I remember correctly is the one that has problems
