Check out this new intake for LS7, L92, C5R
Old 12-01-2007, 11:00 AM
Argon Z's Avatar
Default Check out this new intake for LS7, L92, C5R
I am putting this new intake on my car. I posted up some drawings about 5 months ago. It is finally finished. It has hidden injectors just above the valley plate. Additional injectors up top as seen. It is magnesium with carbon fiber ram tubes. It has transverse counter-rotating throttle shafts and etc.
It is from Kinsler Fuel Injection.
Old 12-01-2007, 11:13 AM
bmax's Avatar
nice, does it use air filters?
Old 12-01-2007, 11:16 AM
Argon Z's Avatar
I am working on airboxes
Old 12-01-2007, 11:59 AM
Yahelou's Avatar
it looks pretty sweet. this might be a dumb question, but what is the carbon fiber things on top of the intake and what do they do?
Old 12-01-2007, 12:34 PM
Screamin_Z's Avatar
those are the runners, just like ur intake...with a twist.
very nice, how much did that set u back? what's the motor that's going on?
Old 12-01-2007, 12:55 PM
1320 killer's Avatar
this looks bad ***. I also want to know what si the total cost of everything to make this swap and what kind of power gains do you expect from this?
Old 12-01-2007, 05:35 PM
2000Hawk's Avatar
That is beautiful, it must look great when installed on a motor. But i would rather put something like that on a corvette/gto rather than f-body, since half the motor goes under the cowl you wont be able to really appreciate it.
-Joel
Old 12-01-2007, 06:08 PM
Tainted's Avatar
I bet that costed a fortune and took a lot of time to fab up. Im sure its very light and will really make the car scream though
Old 12-01-2007, 06:14 PM
Ragtop 99's Avatar
Hopefully less money than the Aussie intake. An ITB set up for $2k or less would be pretty bad a$$.
Old 12-01-2007, 06:31 PM
Tech Fanatic
yellowbird1232's Avatar
It looks similar to Harrop's hurricane intake.
Old 12-01-2007, 07:17 PM
SSNISTR's Avatar
Art......
Old 12-01-2007, 08:06 PM
Jeremiah's Avatar
Good luck with fabbing a breather set up that wont handicap the potential of the intake.
Old 12-01-2007, 10:07 PM
Reject's Avatar
goddamn how high are you going to spin that engine?!
Old 12-02-2007, 01:47 PM
DONAIMIAN's Avatar
If hes using it on the car that I think he is, he doesn't have to worry because its not an F-body.
Old 12-02-2007, 10:02 PM
Jray67's Avatar
If I had that I would have to run a clear hood or no Hood. It's freakin beautiful! How does it work without a MAF though? Is it tuned out?
Old 12-02-2007, 11:47 PM
Mean Green z28's Avatar
Oh damn, I need to go change my underwear ... and wipe off my drool
Old 12-03-2007, 07:10 AM
Argon Z's Avatar
Thanks guys,
Yes, I am working on carbon fiber air boxes.
Some people have used factory computer in speed density mode.
I chose to use an after market Accel ECU.
Old 12-03-2007, 07:14 AM
Argon Z's Avatar
Thanks guys,
Some people have used the factory computer in speed density mode.
I will have dyno graphs before too long.
And Donaimian yes it is going in that car that you are thinking of.
Old 12-03-2007, 07:26 AM
RZRSEDGE's Avatar
Sweet intake! The car should be plenty lite enough, < 2000 lbs.?
Old 12-03-2007, 08:32 PM
ChucksZ06's Avatar
Very trick...is there a common plenum for idle air? I was wondering how that was accomplished? Thanks. Chuck
Quick Reply: Check out this new intake for LS7, L92, C5R
