Map Sensor Help
Old 12-04-2007, 11:48 AM
1998Z20what?'s Avatar
Default Map Sensor Help
how do you know if your map sensor is acting up? my stock idle is high, even in gear. I'm guessing it could be a vacuum leak, although I didnt find a loose hose, I am also leaning towards a faulty Idle Air Control...
Old 12-04-2007, 12:20 PM
slt200mph's Avatar
It could be a throttle position sensor...mine did the high idle and I replaced the TPS and it cured it. A scan with a Tech II will probably tell you what is going on with your engine.
Old 12-04-2007, 01:25 PM
right on, thanks
Old 12-04-2007, 02:47 PM
12secSS's Avatar
A bad MAP sensor (reading too high) will make the car run rich and terrible. High idle can be a host of different scenarios. As mentioned, get it scanned first.
Old 12-04-2007, 03:44 PM
alright, ill go to advance and get it read..i hate going there they **** me off when they act like they are mechanics and dont know what they are talking about...thats why i asked on here first lol
Old 12-04-2007, 04:12 PM
slt200mph's Avatar
If it is a TPS it will only cost you about $30 or so if my memory serves me..might be a little more cause I work at a Chevy dealer and get parts on the cheep...it only takes about 2 minutes to change one out ...
Old 12-04-2007, 06:04 PM
well i drive 30 mins home everyday from work. and when i turn the car off, and wait about ten minutes to turn it back on, it wont start, the engine wont even try to turn over? it was working fine before i did the spark plugs a few days ago? all the wires are on and the plugs are gapped correctly and not cracked? WTF
Old 12-04-2007, 07:38 PM
and to top it off, the guy who tuned my computer is no where to be found, and he went awall and left me with a locked computer so i cant diagnos my damn car
