strait pipes?
Old 12-04-2007, 12:48 PM
DMONEY06's Avatar
Default strait pipes?
im thinkin of runnin strait pipes with no mufflers how do you think itll sound? should i make an H pipe and then with strait pipes all the way back?? any sound clips of the two?? thnx Ned.
Old 12-04-2007, 12:51 PM
2000Hawk's Avatar
If you want to be loud, just toss on some 12" extensions off the collectors dumped. Either one is going to be loud, it doesn't matter which you get. You can always run straight pipes back with and X-pipe, then if things ever get to loud for you, a muffler shop can then just add in some mufflers after the X-pipe.
-Joel
Old 12-04-2007, 12:56 PM
DMONEY06's Avatar
what size would be better 2.5" or 3"
Old 12-04-2007, 01:01 PM
SSpdDmon's Avatar
Try to find a clip of a C5 with a Loudmouth exhaust. That'll give you the best idea of what it'll sound like.
Not my favorite by any means.
Old 12-04-2007, 01:03 PM
Benner's Avatar
I was running 3 inch straight pipe off the Ory for a while. It sounded sick especially with the cam, but it didn't have the low end torque it had with the full catback on so I reinstalled it.
Old 12-04-2007, 01:11 PM
aequitas's Avatar
I am about to do this same thing this weekend. I am going to take off my catback and y pipe and cut the y pipe at the bend to create the extensions. I hope it takes off maybe 50lbs. What is the difference in sound of having it dumped vs. straight, more rasp, deeper tone, etc?
Old 12-04-2007, 01:18 PM
3rdgentug's Avatar
if your talking about running straight pipe off of long tubes dont worry about an H or X especially w/ no mufflers going to be run.
sounds like your going for loud factor
just run 3'' pipe 12'' extensions
you'll be very loud
Old 12-04-2007, 03:10 PM
FireSilverLullaby's Avatar
I would go with an hpipe and less you just want it loud and dont care about the sound at all. I think and h or x would sound better than just straight pipes.
Old 12-04-2007, 03:32 PM
Intense's Avatar
I have straigh pipes but on stock manifolds no muffler with cats and i love the sound.
Old 12-04-2007, 04:19 PM
JohnnyC's Avatar
ORY + LT's + straight pipes will sound like
To each his own I guess...
Old 12-04-2007, 04:33 PM
RE AND CHERYL's Avatar
At least one person with good sense. It'll sound like ***, thats how it will sound. And as already mentioned, the engine runs better and makes more tourque with an actual exhaust insalled.
Loud does not = fast, just anoying.
Re'
Old 12-04-2007, 04:37 PM
TheLS1Kid's Avatar
You will get your brains rattled out with 12" extensions off the collectors.
Old 12-04-2007, 04:40 PM
Grifter's Avatar
I bought my car with 3" straight pipes with Dynomax Bullit mufflers with LT's. It sounded mean but had horrible grond clearance and was a little too loud.
Old 12-04-2007, 04:44 PM
FiredUpZ28's Avatar
Wouldn't it sound like ORY + LT + Catback + open cutout?
My friend has a 94 Formy (different engine I know) with LT's ORY and straight pipes with a CC306 cam and it sounds f*ckin mean!
