cut out?
Old 12-06-2007, 02:57 PM
bigbeefneef's Avatar
Default cut out?
im thinkiing about getting a QTP electric cut out and i was just wondering where exactly you would put it on the exhaust? i was thinking about putting just one right behind the y in pipe where they join together... would that nmot sound good or would i neeed two somewhere before the y??? havent really looked into it much yet so just looking for some opinions... thanks
Old 12-06-2007, 03:07 PM
aaron653's Avatar
under the rear passenger seat
Old 12-06-2007, 04:30 PM
conde'strans's Avatar
I had mine installed on the I-pipe right under the front passenger seat. The closer to the front, the louder it will be. Make sure to have it installed facing to the right side not down in order for the actual motor to have more clearance from the ground. You don't want it installed facing down n then find the motor missing one day after knocking it off with something on the road. I ran the wire with some tie wraps to a hole under the right rear seat and under the carpet into the center console where I installed the switch. I only installed one elect. cutout and it still made a clear difference in Hp gain at the dyno. I already had LT's and a Y-pipe.
Old 12-06-2007, 04:37 PM
ino
ino's Avatar
I agree looks like its suppose to go there.
Old 12-06-2007, 04:39 PM
g-ryde1's Avatar
here you go underneath the rear passenger
(as always excuse the leak aka extreme nastiness underneath)
Old 12-06-2007, 04:42 PM
chromeplated500's Avatar
I have had duals on the y-pipe, had a single on the I-pipe. and now I have a Zed... .which keeps it alot quieter in the drivers seat but is just as loud outside. because when it came down to it, the minute hp gains werent as important.
heres a bunch of pics of each..
http://www.mccordcg.com/mpp/pictures.htm
Old 12-06-2007, 08:33 PM
DarkJuggalo's Avatar
i like the look of the tips facing each other on it lmao
