fast 78mm throttle body
Old 12-06-2007, 10:52 PM
blackZ28LS1's Avatar
Default fast 78mm throttle body
I was just wondering how good those throttle bodies are and what kind of power gain they might give?
Old 12-06-2007, 11:07 PM
Black99CamaroSS's Avatar
You are probably better off using a ported stock TB and you should save some cash.
Old 12-07-2007, 08:40 AM
registered user
ScreaminRedZ's Avatar
Yeah, I payed an arm and a leg for mine. I can't complain about the power my car made (not sure how much was gained just from the TB since I did a cam too). Now I'm wondering if I should stick with the setup I have (LS6 and 78mm FAST TB) or swap to a FAST 90/90.
Old 12-07-2007, 08:43 AM
Internet Mechanic
BlackScreaminMachine's Avatar
If $$$ wasnt a object, people should engine dyno all mods to see a gain.
Old 12-07-2007, 08:58 AM
radkon's Avatar
While I agree with this statement its not that simple. Some mods are done at the same time and would require a LOT of rework to dyno each individual mod. (reinstall tuning etc.) For instance the UD pulley is usually done when a cam is installed. The TB is usually replaced when the intake is replaced and some folks go nuts and do everything at once. I wanted to dyno my car with the LS6 intake and Ported TB then add the FAST but it would have taken too long to mess with everything.
Old 12-07-2007, 09:09 AM
registered user
Don't worry guys, when I'm rich I'm gonna get a dyno and spend all my time dynoing different combinations, lol.
Old 12-07-2007, 09:16 AM
Internet Mechanic
Most varibility can be done via a Locked PCM so it wont allow for any adjustment by the computer, and when I mean $$$ wasnt a object, id wouldnt be working and bored out of my skull, so id be dynoing combos step by step. Only adjust PCM if required.
Old 12-07-2007, 11:44 AM
radkon's Avatar
When I win powerball tonight ($96 Million) I'll get to work on it!
