TSP 100mm Prototype MAF Results!!
Guys we just finished more testing on the all new Texas Speed 100mm Mass Air Flow & the results look awesome!
The 100mm maf package will include a new 100mm maf housing, maf sensor, adapter harness fo your year model, and rubber coupler!
This combo has shown the following dyno results from swapping the SLP 85mm maf for this maf with no other changes!!
SLP 85 MAF Dyno Sheet:
After Install TSP 100mm MAF
All I can say is don't rush out & buy a 85mm maf / lid combo just yet! We should have the TSP 100mm setup with lids ready very very shortly!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Very nice!!! 16hp and 15tq!!!This may be a dumb question but will I need a retune to calibrate for the larger MAF. This is way I havent gotten one yet because people have told me a new one will throw my tune off?
It's not a easy tune as of yet.... We're going to be working on a maf table to send with it to get you started.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
16rwhp/15rwtq is great on a 454ci, but what type of gains will we expect on a lil ol' 346ci?
I'm looking to uprage my MAF soon, but I'm also wondering if this will be overkill on my cam/bolt-on setup. For bigger motors it definitely looks to be the way to go!
Awesome numbers!
Awesome numbers!
Moderator
Can you distinguish between the effects of the airflow
improvement, and the effects of any mixture / airflow
metering skew? Such as perhaps MAP readings across
the pulls, which would show the effect of upstream mods
pretty plainly?
pretty plainly?
