Where are the catalytic converters on a 98 Camaro?
Hey guys, I'm looking to buy a 98 Camaro the only problem is that it has Jet Hot LT headers and a Jet Hot off road y-pipe. I need to add cats to this to make it pass smog. Where are the cats located and how many are there? Is there a catted y-pipe that I can just bolt on and go?
LTs completely change the location of the cats. so basically they'll be where ever you put them.
there are a few companies that sell catted pipes...but they aren't cheap. just shop around the vendors.
you know you'll still fail emissions if they do a visual inspection.
Two cats on the stock car on each side of the Y pipe. If you don't need to pass visual inspection (just sniffer), you can weld in a set of high flow bullet cats to your Y pipe. We sell some really high flow Random Tech units. Give us a call at 204-955-4896 and we can help you out.
