Poly motor mount question
Old 06-27-2003, 10:28 PM
theblur98ss's Avatar
Default Poly motor mount question
I got the poly mounts and I got the ones for an LT1. There were 2 differant part numbers and 2 diferant mounts. One is a good bit larger then the other. My stockers looked to be identical. I just got the motor 'roughed' in and it looks like it's cockeyed. Does anyone have the part numbers so I know for sure. I got energy suspension brand.
Old 06-28-2003, 01:40 AM
felton316's Avatar
Default Re: Poly motor mount question
They should both be the bigger of the two. The Lt1 uses one big one and one smaller one. I believe the part number is 3.1116
Old 06-28-2003, 08:33 AM
I used a 3.1116 and a 3.1127. The smaller one was identical to the stock mount.
Old 06-29-2003, 12:09 AM
Dope's Avatar
Can't really help you, but why didn't you just get the Prothane ones? They are an exact fit for both stockers. I could see trying to retrofit LT1 mounts if they didn't make LS1 mounts, but they do.
Dope
Old 06-29-2003, 08:38 AM
highgmc's Avatar
I used both 3.1116's worked perfect! both the same size
Old 06-29-2003, 09:04 AM
Restricted User
2001 Pewter WS6's Avatar
Ditto....
When is that thing going to see the track???
Old 06-29-2003, 09:15 AM
MyLS1Hauls's Avatar
I used one of the 3.1116s and left the passenger side stock.
Old 06-29-2003, 09:28 AM
highgmc's Avatar
they moved the pick up date a bit back, I pick it up later this week now... I will be at the track SOON.
Old 06-29-2003, 09:05 PM
motor is in the car now and should be running by the end of the week I hope. Not sure about a track date yet. I'm just excited to drive it again.
Old 06-30-2003, 09:37 AM
Restricted User
I will be up the track tomorrow night with Tom. Come up if you can...
Old 06-30-2003, 03:58 PM
highgmc's Avatar
if I am not on my way to get the car I will be at the track tomorrow
Old 06-30-2003, 09:10 PM
I won't be able to make it. I'd really like to but I'm hoping to get the car running for the weekend.
Old 07-01-2003, 06:28 AM
Restricted User
I'll keep you posted how how it runs...
