C.A.I vs Stock ram air, vs aftermarket ram air
Im and completely lost on this. Is it really that much better to get a cai or aftermarket ram air? Or should i just buy a lid for my ss hood and call it a day? Also when you install a cai do you loss the function of the ss hood?
Moderator
Leave the hood alone, get a lid, forget the SLP CAI. Putting
it on my car raised IAT readings. The hood path is cooler
than stainless ducting an inch off the radiator. Maybe a
plastic duct is less of a problem but if you live in the South
you aren't going to like air from an inch off the pavement
in the summer, neither. If you've got a regular hood, get a lid
and seal off the nose space from the engine compartment,
take a steak knife to the foam that obstructs the "nostrils"
in the Camaro bumper and let breathe that way. The nose
pocket is pretty cool air as long as the plastic divider panels
are intact and air is let in unobstructed. Not ducted, but free
path cold air is fine. Ram air is a myth on the street but cold
air is good.
air is good.
i think everyone would agree with me that you should get a lid, i have the fast toys ram air which is like the slp ram air. the lid made a good difference, and the fast toys ram air made a very good difference, i understand where jimmy blue is coming from in what he is saying, but it performed much better than the factory hood every could. i vote for a lid of your choice and the fast toys ram air if you want more power.
also ram air is not a myth it is there but really really small...at around 100-110 mph with proper sealing a ram air can see around 0.1 psi increase...also helps with the motors vacuum it creats when it sucks air in...reduces the suck in a way
Jimmyblue tried the SLP CAI which is not a ram air kit. It draws air from half way up the radiator instead of pulling it off the lower air dam like the FTRA. Your IATS will definitely go down with the FTRA installed compared to stock, an SS hood etc.
Ram Air it not a myth but takes very high speed to build significant positive pressure about atmospheric. However, you see Volumetric Efficiency increases from ram air well below those speeds. Check out the article at www.installuniversity.com
Those increases also yield better fuel economy (5-7% on average).
You can use our FTRA with any aftermarket lid or with our new 85mm air lid (which can be used with the stock MAF using an adapter we have available).
Cheers!
Cheers!
FTRA all the way. When I sealed and debaffled my hood(ws6) the car sounded awful. Standing in front of the car the intake swooshing was way loud. So loud it over powered the exhaust. Plus I had to cover the air filter every time I went to the car wash. I just bought the ftra and I'm gonna make the car a bottom breather. Either way the car will get sufficient airflow. This was just a personal prefference on my part. I also want to add that Fast Toys has great customer service and answered all my questions promtly.
In my past experience, the FTRA (I'm in Florida) caused my car to severely overheat in traffic and on long trips driving at about 80+ mph. Not only did it pull hot air from the pavement, but, it also was blocking air crossflow through the radiator. Now, with a fully functional ram air hood and taller ram air airbox, the car stays very cool and I feel a power difference at higher speeds. Even after removing the lower air dam, the car still stays cool mainly IMHO because (1) cooler air is not blocked by the FTRA from flowing through the radiator and (2) cooler air coming in from up top. I'm with JimmyBlue because of my experience with both types of ram air and also because JimmyBlue has proven he knows his **** ... time-and-time again.
Pontiacerator
With hood scoop air ....
Yeah, that's pretty much what I was stating, however, you'd have to quote my entire paragraph because it states the current functional ram air feels better due to the de-installation of the FTRA and the current installation of functional ram air ... directly pulling in cooler air from up top. After de-installing the FTRA kit, the radiator was not not restricted from cross-flowing air through the radiator. These type 'ram air' systems are known to cause overheating in many cases, especially in the South where the air from the pavement is very hot. Even up north in the summertime, I'd still want cooler air passing accross the MAF wires and IAT sensor, coming into my motor ... anyone can do a search and find overheating has occured using the FTRA-type kits ... many, many times.
Not just speaking only of the FTRA kit, but, any kit of this design which blocks air form cross-flowing through the radiator and pulls hotter air from just above the pavement.
I guess this would be in the top 10 for 'subjects which were beat to death on LS1Tech.'
If you have a WS6 or comparable hood, then you may get similar results from a kit that seals the hood and the airbox, but for the rest of the world a ram air kit is the way to go.
And, uh, ram air is a myth on the street? While you're definitely not creating enough air pressure to force it into the engine (as a blower would), you are creating a high air pressure area inside the airbox. Which helps to ease the strain on the engine try to suck air in. Similar to the way a less restrictive air filter works. You saying that those don't exist either? If so, then somebody needs to call japan and tell all the sport bike manufactures that they've been doing it all wrong for the last 15 years on their purpose built race machines, since ram air is just a myth.
Jon
And, uh, ram air is a myth on the street? all the sport bike manufactures that they've been doing it all wrong for the last 15 years on their purpose built race machines, since ram air is just a myth.
Jon
