What Heads!!!!!!!!!!
Old 12-30-2007, 07:12 PM
neals98's Avatar
Default What Heads!!!!!!!!!!
I have a stock ls1 short block with a 585/595 lift comp cam, ls6 intake. ss3600 YANK stall,373 gears,pacsette lt headers. I am going to spend up to 1,600.oo on a set, let me know what you think............THANKS
Old 12-31-2007, 07:42 AM
neals98's Avatar
bump!
Old 12-31-2007, 08:04 AM
bryan04h's Avatar
ha i can't tell time, and patriat heads will probaly help you out for the price...check the sponsers...thunderracing.com, texas-speed.com, ws6store.com ect ect all have head packages
Last edited by bryan04h; 12-31-2007 at 11:49 AM. Reason: can't tell time anymore...to much time spent in the desert
Old 12-31-2007, 10:44 AM
neals98's Avatar
I posted it yesterday and i bumped it today i think that is longer than 30 mins. THANKS for the help though...
Old 01-01-2008, 07:46 AM
neals98's Avatar
bump for the day
Old 01-01-2008, 06:24 PM
crainholio's Avatar
Get aluminum heads!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11one
Old 01-01-2008, 06:28 PM
Gregory's Avatar
Livernois has a selection in your price range. You can ask them for flow numbers if you want a closer comparison.
Old 01-01-2008, 08:17 PM
bad2000z's Avatar
Check out TEA too.
Old 01-02-2008, 12:03 PM
neals98's Avatar
bump for the day
Old 01-02-2008, 12:09 PM
Shawn @ VA Speed's Avatar
Any of the ported ls6 heads will work fine,but stay with the stage 1 packages with 2.02 being the biggest valve.Anything biiger than that you will have to spin the engine to the moon.
Old 01-06-2008, 10:26 AM
LivernoisMotorsports's Avatar
I would recommend our stage 3 heads w/ that cam. They are on special for 1499 right now. That includes full CNC porting. Manley 2.02 int 1.575 exh valves, manley titanium retainers. and our exclusive surface enhanced dual spring assm. good to .690 lift.
another good one would be our stage 2 heads, basically the same, except they use production LS2 valves (they would flow a little less then the 3's). they would be 1349
both flow over 305 on the intake and over 235 on the exhaust.
