How do I wire my 5" Autometer Tach to my LS1?
Old 01-01-2008, 03:15 PM
Mike96z's Avatar
Default How do I wire my 5" Autometer Tach to my LS1?
Alright, Ive wired a tach to a LT1 which is pretty simple to the coil wires, but not sure if that works the same on the LS1, if anyone has a diagram or anything of how to connect a Autometer tach to the LS1 please let me know. Its a 98 LS1 and if you could provide which wires and colors I connect to, that would be great. I know red is for power for the light, green is for the tach signal, black is for the ground adn white is for switched power.
Old 01-01-2008, 04:04 PM
Grimes's Avatar
https://ls1tech.com/forums/showpost....6&postcount=26
good info in that thread, and the link in it
Old 01-01-2008, 04:09 PM
chewy99ws6's Avatar
green wire goes to the #10 wire on your PCM, that is how mine is wired up. ^ that link should help you out too.
Old 01-01-2008, 05:02 PM
SweeTbone's Avatar
Actually, he has a 1998, so he would hit Pin #35 which is a white wire. 97-98 LS1s had different pinouts then 99-02s.
Check this out. --->
https://ls1tech.com/forums/showpost....7&postcount=54
3 wire hookup. + , - , and Pin #35 right out of the (blue) connector on the PCM. It's a white wire that will be tapped and go to the tach signal on your tach/shift light.
Old 01-01-2008, 05:12 PM
chewy99ws6's Avatar
oh yeah crap I forgot about that my bad.
Old 01-01-2008, 06:44 PM
Restricted User
socmguy's Avatar
Actually, what you should do with that 5" ricer tach is throw it out the ******' window
Old 01-02-2008, 01:38 AM
Mike96z's Avatar
yea so you can pick it up lol. ima keep it
Quick Reply: How do I wire my 5" Autometer Tach to my LS1?
