Small vaccum like pumpner the front of intake driver side
Old 01-01-2008, 10:09 PM
167camaro's Avatar
Default Small vaccum like pump near the front of intake driver side
Hi, guys, i am almost ready to start up the 2000 ls1 with 6 speed i am putting in my 67 camaro. My question is, there is a small electrical vacuum pump looking thing near the front of the intake on the driver side of the engine. It has a connector that looks like it accepts a 2 wire weather pack connector. I am wondering what this is for and if it is okay to remove it. It had 1 line going to the back of the throttle body. I removed it and used a vacuum plug to block it off. I have had the emissions equipment deleted in my computer and am hoping it is an emission related piece. Thanks, Aaron
Old 01-02-2008, 12:12 AM
ssheets's Avatar
Are you talking about the IAC?
Old 01-02-2008, 12:19 AM
Da Swami's Avatar
I think he's talking about the fuel EVAP system....?
Old 01-02-2008, 12:34 AM
167camaro's Avatar
In the pic you posted the piece i'm talking about is behind the iac. It is attached to the black plastic hose i can see in the pic. Looks like it is hiding under your wire harness. Right above valve cover.
Old 01-03-2008, 09:12 AM
fuseone's Avatar
if your talking about the one i think you are talking about its for the evap
Old 01-03-2008, 10:27 AM
RE AND CHERYL's Avatar
That's the Evap solinoid. Not really a "emissions" part, but I guess so. Sounds like you don't have a plug to connect to it so I guess your harness dosen't have it. Actually a good thing to have and could be connected to the vent line on the fuel tank.
Re'
Old 01-03-2008, 05:16 PM
167camaro's Avatar
Thanks for telling me what it is and what it does. I appreciate it.
