Anyone running this throttle body?
New 90mm throttle body that makes more hp
FRE's 90mm throttle body is superior to all throttle bodies currently on the market today . It has been tested on an engine dyno to make up to 7hp (flywheel hp) over other 90mm throttle bodies depending on what you are using it on (Intake manifold , cam , heads , etc.) It's unique oversized inlet is straight through and not tapered on the inlet with a large radiused edge , and the shaft that holds the blade is cut in half so it is only on the back . It has a slightly larger outer diameter , so you can not use a stock bellow or intake tube , SLP smooth bellows work for f-bodies and our induction system (New Era) will work with your 04 gto . If you are trying to squeeze a few more hp out of your 90mm induction set up , this is the way to go !
