Ls6 Pcv??
Old 01-06-2008, 06:02 PM
miller456's Avatar
Default Ls6 Pcv??
I bought stock 02 heads for cheap b/c my 98 had a miss shift and bent valves so this was a cheaper route. I already have the valve covers coming but what I dont know is is the ls6 pcv upgrade necessary? I mean i know ill have it all apart already and could change the valley cover and complete to this system easily just wondering if i really need to or not?
Old 01-06-2008, 06:43 PM
Tainted's Avatar
nope you can keep your ls1 style. i had some oil consumption issues so im upgrading to the ls6 pcv.
Old 01-06-2008, 06:49 PM
miller456's Avatar
How bad was the consumption and how did u u notice the issue? Ive been trying to read the best i can about this system what are people using for a catch can and the details of how this works are simple im sure but could u school a newb like me?
Old 01-06-2008, 06:58 PM
Tainted's Avatar
well you can tell if youre using oil just by checking it (duh) i was using about a 1/2 quart every oil change and it was all over my TB and on the inside of the intake. Im in the process of reuilding my motor now and I was originally planning to just run a catch can, but when the stock pcv lines broke I said **** it and bought the LS6. The LS6 draws from the valley with an oil/air serperator, some people have good results of using less or no oil, otheres dont. So im gonna try it anyhow, besides, I get to get rid of all those ugly black hoses.
Old 01-06-2008, 07:02 PM
miller456's Avatar
LOL yea i knew checking it but I was more curious of if you were seeing more oil in your intake or what. Also if i get an ls6 intake does this change the pcv conversion any?
Old 01-06-2008, 07:05 PM
Tainted's Avatar
nope, I run an ls6 intake. I had more oil in my intake, it was almost like puddles of oil.
Old 01-06-2008, 07:09 PM
miller456's Avatar
Great thanks for the help pretty much answered all my questions the conversion looked pretty straight forward to me and i agree on the ugly black hoses everywhere.
Old 01-06-2008, 07:14 PM
Tainted's Avatar
http://thunderracing.com/catalog/?ac...vid=3&pcid=316
Old 01-07-2008, 12:39 AM
1redultraz's Avatar
I had the same problem my self on my 01 and i did away with it all , i cap everything off and put a breather were the oil cap was and put a 5.3 pcv valve with a small piece of hose on the end of it. And i it solved my oil problems . My oil level hasn't moved on my dipstick for a month and i am a daily driver. It only cost me $4.99 for the breather cap, and $3.99 for the block off caps. If you need pictures ,i can send them to ya!!!!! just pm me
Old 01-07-2008, 06:36 AM
miller456's Avatar
pm sent thanks for the help
Old 01-07-2008, 08:55 AM
massls1guy's Avatar
I would buy it from SDPC if I was you:
http://www.sdparts.com/product/12568002/COVER.aspx
Old 01-07-2008, 10:08 AM
INMY01TA's Avatar
I would skip the LS6 valley, I did this mod years ago and got just as much oil in the intake as before. I run a catch can now, problem solved.
Old 01-07-2008, 07:07 PM
1redultraz's Avatar
Or you could do it the way i did, and save money both ways and don't have that excess under the hood, and only cost 10.00 at the most.
Old 01-07-2008, 07:28 PM
silverLSWON's Avatar
you might have to modify your engine block a little for the valley cover. i know on some of the blocks you have to grind a spot down a little bit because the cover wont sit down all the way. i think it's the some 00 blocks and older. i have the ls6 pcv on mine but i didn't have to grind at all cuz i have an ls6 block. i'd try the 8 dollar pcv valve from gm first before you try the valley cover. it might work
Old 01-07-2008, 08:17 PM
INMY01TA's Avatar
Ya I had to cut the casting boss off my 01 block to fit the valley cover. Definately wasn't worth it. I say skip it.
Old 01-07-2008, 09:39 PM
Tainted's Avatar
installed mine today, i got a 2002 block and I had to cut the casting block off. dunno if it has helped any, tomorrows the big day for starting the car up again
