open headers or not?
Old 01-06-2008, 07:30 PM
lightemupls1's Avatar
Default open headers or not?
are open lt headers ok on a 2000 ws6 m6 with a cam (230/236 .581/.590 112 lsa) and a custom tune only? i have heard some people on here say no way for open headers. is that because of it being so loud or is there something else? this car is mostly a weekend driven car. the guy at the performance shop that is tuning it says it will be fine.
Old 01-06-2008, 07:36 PM
Benner's Avatar
There's a possibility of burning your exhaust valves with open headers. Plus you'll be losing alot of low end torque. I would say you'd be better off installing a full exhaust with a cutout in the I pipe
Old 01-06-2008, 07:41 PM
Tainted's Avatar
youre gonna get a ticket and how hate loud it is. its just a blaaaat loud sound, no tone at all
Old 01-06-2008, 07:43 PM
El_Diablo's Avatar
tuning it would be a problem. The o2 sensors will not heat properly and will throw your A/F ratio all over the place. If you're dead set on running them open you're gonna need at the very least, some 18" extensions
Old 01-06-2008, 07:46 PM
Jared 3870's Avatar
The only time I have heard of people ruining valves is whenever the engine is ran with NO exhaust on it at all, and possibly shorties. Longtubes have long enough primaries that cold air can't make it all the way back up to the valves. The loss of low end torque would be no different than having an open cutout.
The big draw back to open headers on a car that still uses the O2 sensors is that fresh air can throw off the O2 readings and cause the computer to interpret a lean condition and run rich. 12 inch length of pipe on each collector will minimize this.
Old 01-06-2008, 07:51 PM
no i am not dead set at all about this open header thing. i dont like the idea of it but the guy at the performance shop i'm dealing with said it will be fine. i dont want to damage anything so i'm wandering now is there any way to mount 1 cat somewhere on the exhaust or do i have to do two at the y pipe?
Old 01-06-2008, 08:54 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
AGREED..from all I have read on this subject.
Old 01-06-2008, 10:33 PM
RIDINFILTHY's Avatar
too loud!!!!doesnt sound very good
Old 01-06-2008, 11:47 PM
Brian2006's Avatar
This would be about the worst decision you could make (IMO). Burning up your exhaust valves, and ungodly amount of noise, fuel efficiency cut in half, and power dramatically reduced all come to mind.
Old 01-07-2008, 03:37 AM
bryan04h's Avatar
atleast through a y or x pipe on it!
Old 01-07-2008, 07:45 AM
if i get him to delete all o2 sensors and run a full exhaust to dual tips no cats no muffler would that work ok?
Old 01-07-2008, 12:54 PM
chrs1313's Avatar
yeah that would work fine but i wouldnt delete all o2 sensors just the rear ones that would be after the cats...unless you are planning on running the car in closed loop mode...just get an ory and any catback could even be stock and put a cutout in the i pipe like stated...if you dont like the idea of a cutout then get a good catback like hooker or magnaflow...etc
Old 01-07-2008, 01:50 PM
what is closed loop mode, i thought i might have heard the guy at the shop mention something about that?
Old 01-07-2008, 04:46 PM
phoenix305's Avatar
closed loop operation means that the computer runs the car off of an assumed table of inputs. When in open loop the computer takes in sensor readings ie;the front 02 sensors, to control a/f ratio. You could run it in closed loop, but it would be pointless to do it that way and the car would not adjust for any variable you might run into.
Old 01-07-2008, 04:57 PM
RareBreed0295's Avatar
Don't do it. I drove my car with just the kooks headers on it to the exhaust shop and it was just like a dragster. I thought i wanted my car to be loud until i heard staraight headers. Its unreal how loud it is.
Old 01-09-2008, 12:23 AM
jsteele90's Avatar
definately not good at all. either sound or performance wise.
Old 01-09-2008, 05:05 AM
green28's Avatar
+1 I ran at the track with open headers because I was shipped the wrong y-pipe and it took a month to get the right one. Anyway I ran .2 slower with open headers than I did with the y-pipe and exhaust. And it had no ***** down low.
Old 01-09-2008, 08:22 AM
ok i see about the open header thing, but like i had asked before what about a straight open exhaust? headers straight back to dual tips at the rear of the car, no cats no muffler , i would think that would deaden the sound some. has anyone run their exhaust like this.
oh i talked to the guy thats working on it and he says the upstream front o2's will go in the headers.
Old 01-09-2008, 10:34 AM
bryan04h's Avatar
^^^there are a lot of guys running running that exhaust, the sound is good....mostly because the exhaust isn't dumped right under your ***...
Old 01-09-2008, 11:37 AM
Midnight02's Avatar
Open headers are ridiculously loud (in my opinion) and you should sacrafice a bit of low end torque. I have long tube headers, an off road y and have an electric cutout in my intermediate pipe.....that still gives me a very agressive exhaust note and a good bit of the low end torque is back!
