What did you do to get rid of the floorboard banging associated with long tubes?
Old 01-07-2008, 07:05 PM
BlackZ28629's Avatar
Default What did you do to get rid of the floorboard banging associated with long tubes?
just as it says...I bent the ds collector down a little bit and it helped some...but it is still present...
Old 01-07-2008, 07:35 PM
black01_WS6's Avatar
you can do motor mounts, muffler hanger welded in, bang the floorboard- not to wise. Add padding where it bangs.
Or just mess with it till it doesn't bang anymore.
Old 01-07-2008, 07:38 PM
Trunion King
bene's Avatar
Mine came with torque stop.
Old 01-07-2008, 07:45 PM
what kind of "padding" would resist the heat? I pretty much did all I can do and now its welded...
Old 01-07-2008, 07:52 PM
transAm-98's Avatar
WEll if you want to do it right than you should do the poly motor mounts. It fixed my problem and it will make the car a fill a little more responsive when you're on the gas
Old 01-07-2008, 08:06 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
MYSELF.??? I bought EDELBROCKS.
Old 01-07-2008, 08:14 PM
99nbmws6's Avatar
if you dont want to go with motor mounts i saw thunderracing had a rubber part for that i think it was only like 40bucks. check it out under i think exhaust accessories
Old 01-07-2008, 09:28 PM
Yun Gunz's Avatar
made a solid mount to keep motor from twisting, worked like a charm.
Old 01-07-2008, 09:43 PM
damn it!!! and they sure wouldve been easy to change with it all out...and I read the advice for that but no one said it cures that banging problem or I would have done it!
Old 01-07-2008, 09:48 PM
jetlag's Avatar
The the mount bene posted is a good solution...or you can just jam something in between the pipe and floor...like a valve spring..haha
Old 01-07-2008, 10:07 PM
Yun Gunz's Avatar
My mount goes from the Passenger side head to the strut tower bolt, took like 10 minutes to make, wish I had a camera. and it don't look like poo either
Old 01-07-2008, 10:21 PM
Tainted's Avatar
Mufflex Y pipe bump stop hanger
Old 01-07-2008, 10:26 PM
yeah, but does this mufflex hanger have the strength to hold the pipe down and not hit the floor ALL the time, and what does the install include?
Old 01-07-2008, 10:30 PM
Tainted's Avatar
install is stupid easy. its jsut a normal ol exhaust clamp, but you bolt a bracket to the heat sheild and it uses 2 rubber muffler hangers to force the y pipe down so it doesnt bang any.
Old 01-07-2008, 10:33 PM
transamwes's Avatar
+1 for polly motor mounts and tranny mount!!! did mine last week with pacesetters in the way and with the car on ramps it took me 12hrs total and it sucked but no more bangin at all!! and driveline feels more solid
Old 01-07-2008, 10:42 PM
transamwes's Avatar
oh and i was going to just go with the mufflex bump stop hanger to cure this prob. and actually ordered one from thunder racing about 3 1/2 weeks ago but they were on backorder got an e-mail stating they shouldnt be more than a week out and i still have not heard back!!! would have been alot easier to install than the motor mounts but seems like a band aid fix to me...
Old 01-07-2008, 11:00 PM
Tainted's Avatar
lmao i ordered my hanger thursday and got it today. got mine from thunder racing as well
Old 01-07-2008, 11:02 PM
Kleeborp the Moderator™
MeentSS02's Avatar
To get rid of the banging associated with long tube headers, I bought QUALITY headers. No banging, and no need for a bumper...that goes for the stock motor mounts and my new(er) poly ones as well.
Old 01-07-2008, 11:04 PM
Tainted's Avatar
well im using a good header, but im using a jet hot Y pipe
Old 01-07-2008, 11:09 PM
MeentSS02's Avatar
You wouldn't know quality if it jumped up and hit you in the face...
