Help installing summit cutout....
Old 01-11-2008, 04:18 PM
alfred's Avatar
Default Help installing summit cutout....
ok me and my friend tried to tackle the job of installing my cutout and we basically got the piece of exhause off and tomarrow we are going to finish the install. my question is, i bought a 3 in summit cutout, will that just slide right over my stock exhaust? i plan on just clamping it for now and getting it welded in a week or so when i have time. will the clamps be fine for a week before i get it welded?
thanks
Old 01-11-2008, 04:38 PM
99mongooSS's Avatar
maybe. but if your running a catback with the 2.75 od end that connect to the y-pipe a 3'' cutout will be too big. we ran into that problem on my buddies WS6
Old 01-11-2008, 04:41 PM
alfred's Avatar
well we are putting it in the I pipe right before it goes over the axle where everyone told use to put it. they told us to get a 3 in cutout. how big is the stock exhaust?
Old 01-11-2008, 04:43 PM
99mongooSS's Avatar
are you cutting the pipe. We stuck it in between the I pipe and the ypipe on my buddies
Old 01-11-2008, 06:06 PM
alfred's Avatar
yea we are cutting the pipe. i believe it is the I pipe? im not a ls1 guy. i know mustangs. its right before it goes over the rear axle right after the y pipe i believe. whre is the I pipe?
anyways, will my summit 3 in cutout fit over m stock exhaust?
Old 01-11-2008, 06:12 PM
alfred's Avatar
nvm i dont think its the i pipe. its the single pipe right after the y before it goes over the rear axle. where everyone puts them.
Old 01-11-2008, 06:39 PM
ryanfx's Avatar
that's the I pipe
If the exhaust he has there is 3" OD and your cutout is 3" ID then it should slip fit fine.. otherwise you're gonna need to weld it up there.
Old 01-11-2008, 07:58 PM
alfred's Avatar
what is the stock size on the i pipe?
Old 01-11-2008, 08:01 PM
dug
dug's Avatar
2.75"
youre gonna have to weld
Old 01-12-2008, 01:10 AM
99mongooSS's Avatar
yep gotta weld
Old 01-12-2008, 02:38 AM
dug
dug's Avatar
If your gonna weld anyway, just cut off the catback. I never capped my cutout with the stock exhaust. sounded too good
