Cutting ls1 valley coolant tubes
Old 01-13-2008, 11:19 PM
71chevellels1's Avatar
Default Cutting ls1 valley coolant tubes
Has anyone had to do this before instaling a wieand intake? Do you really have to do that? Mabey i just reading it wrong,
http://www.holley.com/data/Products/.../199R10267.pdf
Old 01-14-2008, 01:50 PM
anyone?
Old 01-14-2008, 01:56 PM
PAGregSS's Avatar
It's the exact same as an LS6 intake. Instead of cutting the pipes, just get the front crossover pipe and the rear plugs.
Old 01-14-2008, 02:38 PM
99mongooSS's Avatar
x2^ its just cutting each individual block in the back and then making one tube-crossover in the front. just go get the ls6 tubes they cost about 45-50 dollars, and pretty easy to find. I think slp has them and I bet lm performance has them.
Old 01-16-2008, 12:22 AM
5w20's Avatar
its cheaper to cut and weld the current ones than buying those ls6 coolant tubes
Old 01-16-2008, 09:24 AM
24KTA's Avatar
I got mine from GM dealer, then ordered the block offs for the rear. All you have to do is get one off of a 01 or newer.
