is there Lower temp fan switch for 99 ls1?
Old 01-30-2008, 07:49 PM
bigfatls6's Avatar
Default is there Lower temp fan switch for 99 ls1?
I don't really want to buy a programmer to lower my fan cut on and off temp does any one make a fan switch to install on the ls1s?
Old 01-30-2008, 08:07 PM
ta_06374's Avatar
Its needs to be tuned into your pcm to turn on earlier, or you can do what I did and run a wire from the fan relay to the fog light relay which i dont use. So when I want the fans on I just hit the fog light switch. It never realy gets hot anyway with the 160 stat.
Old 01-30-2008, 08:40 PM
bczee's Avatar
The fans are controlled by the PCM, the PCM It reads the ECT sensor which will trigger the Fan Relay at the prorammed setting. The key word here is sensor vs. switch.
You don't want to reprogram the PCM for the fan setting, then you don't have much choice if unless you wire in a manual switch to activate the Fan Relay or use a extra temp switch in the passenger side head to trigger the relay.
Old 01-30-2008, 09:10 PM
LS1ne's Avatar
SLP makes a nice manual fan switch!! i have one. it has a hi and low setting
Old 01-31-2008, 05:56 AM
bigfatls6's Avatar
What is the part # for the slp fan switch and what do you mean by high and low setting? Does it have a higer and lower temp setting for it to come on and shut off?
Old 01-31-2008, 08:49 AM
omcar's Avatar
I have the slp switch as well... works fine.
Old 01-31-2008, 08:54 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
No, you turn it on yourself and you can either turn on the high speed fans or the low speed fans
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 02-01-2008, 09:38 AM
bczee's Avatar
You can divorce your fan setup completely from using the PCM if you want.. both SPAL and Delta make Fan Controller that you can program the fan start and stop.. I am using the SPAL controller.
Old 02-01-2008, 10:25 AM
teke184's Avatar
i also have the SLP unit.....most of the sponsors probably have it --->
in the "off" position the fans work according to the computer settings. the "on" settings are either high speed or low speed, and are running untill you put the switch in "off"
i've run it on my old LT1 and now my LS1...works great. but don't forget to switch it OFF....it'll stay on with the ignition turned off. and drain your battery.
i found that if the engine gets hot, the low setting will barely pull the temps down if you're still sitting still in hot weather.
but if you turn on the high fan setting...it will pull the temps right down to whatever your thermostat will equalize at, which is about 170-175 for me with my 160 stat.
Quick Reply: is there Lower temp fan switch for 99 ls1?
