crank f*ck up! help!!!!!
Old 07-10-2003, 02:09 AM
98sspullin'em's Avatar
Default crank f*ck up! help!!!!!
ok, it took us a good while to get the stock pully off, then we put the crank bolt back in there without the pully on to turn the chain so the dots would line up, then we had to get a air gun set it up to 130 and take the bolt back out! it would barely move at 130, but we finally got it off! so when we did, the last couple threads were flattened out! so without messing up my crank anymore, what is the best way to go about putting the new pulley on and tightining it down to 240, then taking it back out, then putting the new one back on? should i rethread the crank or what? i do not want to change that damn crank! ANY input would be more than great!
Old 07-10-2003, 02:18 AM
C4VetteLS1's Avatar
Default Re: crank f*ck up! help!!!!!
ack well....id say get a tap set and run a tap through the crank a few times....
Ive reused the stock balancer bolt about 10 times so far...just put some blue low strength rtv on it everytime...
and its such a pain to get 240 lbs of torque, i just pull till i cant anymore and call it good
150lbs probably..
Old 07-11-2003, 11:18 AM
other thoughts?
Old 07-11-2003, 11:21 AM
Constrictor 98TA's Avatar
You got some really good suggestions in your post on LS1.COM. Why not try one of those and see what happens?
Old 07-11-2003, 06:46 PM
JaSSon's Avatar
I got one for you, buy a MUSTANG!
Old 07-11-2003, 09:28 PM
keep talking boy, well settle this at the track when my car is done and we will see who your daddy is then!!!!
Old 07-12-2003, 08:54 AM
JaSSon's Avatar
Son, Wake up youre having a bad dream. Your DAD.
Old 07-12-2003, 09:36 AM
alright big boy!! looks like this is going to get nasty! Just playing man, but can't wait to see how we are going to be up against each other, by then i should have the FTRA on, got the smooth bellow and t'stat in too!
Old 07-12-2003, 09:43 AM
Speedfreaks101's Avatar
Run a tap in the crank snout and then fill the cylinders with water so that the pistons cant move in the bores and then you can get as much torque on it as you want.
