Need shorter ls1 plug wires.
Long story short i need ls1 plug wires that are about 1inch shorter than stock. Do any gm cars have shorter wire that will work with our coils and plugs. Or where can i get a "make it yourself" wire set that will work with an ls1?
Thanks
Alex
Thanks
Alex
Check these out:
http://www.thunderracing.com/catalog...vid=3&pcid=104
17-32079 MSD 8.5mm Super Conductor Spark Plug Wires, Universal LS1/LS6, Universal wire sets are supplied with the spark plug side terminal and boot installed and are supplied with the coil side loose so you can route and cut your wires the the proper length.
Check these out:
