didint know where to post
Could be numerous things:
-Did you unplug the a/c to do the swap? If so did you hookup the lines/ get a recharge?
-Did you check the vacuum lines underhood that handle the heat/ac system? One maybe cracked or unplugged.
-Did you hit the heater box when doing work? You may have cracked it.
What happens when you try to turn it on currently?
Its definitely the vacuum line. After removing my AIR I acidentally unhooked that line and nothing would blow through the vent.
I just felt around back there and was able to reconnect it and the ac blew through the vents again.
Restricted User
If it's not that one in the back of your intake, check the blender valve to the right of the PCM as your's looking at the motor from the front. If it's cracked just get a new one. They're not hard at all to replace.
yea the one of the left of the pcm i didint hook up yet i know where it hooks up but does it go on the top of bottom of the connector one sides black the others like a white tanish or does it not matter and then the other ones by the back of the manifold right? ill take a look today if it stops snowing
