UMI TB and surging
UMI TB and surging
Curious if any of you guys had any problems with the UMI 90mm TB's?After adding that and a fast intake the car surges and the idle hangs.It has a SD tune from a good tuner and thats not the issue.It also did it before the tune but not as bad.If anyone has any thoughts I would appreciate it.
I've got a UMI 90mm and have never had any issues with it. It is tuned with a MAF though not SD. What intake and TB did you have on it before? If you went from a 78mm tb and intake then the tune will change and cause issues. You should have it re-tuned with the new stuff on it. Besides you should try and take full advantage of your new setup!
