Fast Toys Velocity Stack??
Old 02-07-2008, 08:34 AM
Nightrydass's Avatar
Question Fast Toys Velocity Stack??
http://fasttoys.net/shop/product_inf...oducts_id=1251
Hmm, is this as good as it sounds; anyone use it? I really don't want to spend $300 on a new STOCK sized TB that is P&P'd; matter of fact, i don't want to spend any money on a new TB that is stock sized, and i don't really want to be bothered with P&P my own TB if this is worth it.
Do you get the same results as having a P&P'd TB? Im very intrested...
Old 02-07-2008, 08:49 AM
Bad Blue WS6's Avatar
far from it.
Old 02-07-2008, 09:00 AM
no title here
skyhighsami's Avatar
Why would you add a resriction to the ariway? Kind of like a Tornado IMHO
Old 02-07-2008, 09:04 AM
radz282003's Avatar
IMHO - I'll stick with my port/polish/epoxy'd TB. It's not expensive but I agree; I wouldn't spend more on a stock sized TB.
Old 02-07-2008, 09:24 AM
never thought of it that way. is there an article on how to P&P your TB (sry if it is already opn this site, i did a search and didn't find anyting)
Old 02-07-2008, 09:32 AM
Once you open up the stocker,,they flow quite nice,,there are plenty of high powered cars running Stock TB's (some not even PnP'ed)
when u think about "buying" an aftermarket TB,,if your changing your size (90mm) it becomes "worth it" to spend 400.00,,other than that, that cash can be spent on other more inportant mods since your stocker can become a performance piece. Guess it really depends on your goals and budget.
Old 02-07-2008, 09:39 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I think you guys are confusing the purpose of a velocity stack.
Either right off the tb:
(Big pic)
http://www.szpakmfg.com/stack.jpg
OR:
Off of an intake
They work.
Old 02-07-2008, 10:07 AM
im just looking for an easier (cheaper) solution to porting my TB or swapping it out. I can't find a write up on how to P&P your stock TB; i ASSUME it is the same process as P&P you MAF, but you know what they say when you "assume"....
Old 02-07-2008, 10:43 AM
Internet Mechanic
BlackScreaminMachine's Avatar
There are many people on tech that will send you a ported stock unit, and you swap it out send yours back, kinda like a core charge
Old 02-07-2008, 12:03 PM
I dont think the OP is looking at that huge tube you got goin on there,,,probably a plastic fitting that sits inside the TB, only guessing
it is not the same as doing a MAF,,you can very easliy screw stuff up if not done correctly....and in a bunch of different areas,,,blade area, hump area, thin areas, coolant line areas, etc, etc, etc.
Old 02-07-2008, 12:35 PM
good look, thats y i asked
Old 02-07-2008, 01:13 PM
so is the velocity stack worth a shot, or would i risk losing power? It doesn't look like it blocks flow
Old 02-07-2008, 03:07 PM
good look????? If your buying stuff for looks, then go for it.
Old 02-07-2008, 03:21 PM
no i meant "good look" as good looking out, lol
Old 02-07-2008, 03:50 PM
ah,,,now i understand.
Old 02-08-2008, 04:24 PM
OWN3D BY MY PROF!
Velocity stacks work, period. The problem you're going to run into with out platforms is hood clearance and filtering the stack. It would be cheaper to just port your own throttle body that buying a velocity stack. Try a search. There's about a bajillion write ups on how to do it.
Old 02-08-2008, 04:31 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Did you read the original post? Click on the link? The product in question does not work...
Old 02-08-2008, 04:51 PM
no title here
A velocity stack isn't what you are looking at because it doesn't come out past the TB. A velocity stack allows you to fine tune the power band taller more mid range, shorter more topend. From what that looks like is only "smoothes" out the airflow. I would think it is a waste.
