SLP Headers, Passenger Install, prying tranny
yes, the infamous passenger side SLP header help needed,,,
I know these arnt everyones favorite headers, i already understand that, the clearance, etc, etc, etc,,,
i just need help with..
The tranny brace,,,does removeing the 4 15 mm bolts that hold the big black (stock, 2000 WS6) tranny brace really allow me enough room??
What about the shifter,, no need to do anything, it will just move with the tranny as my buddy does the 2x4 pry move?
Dr side is no issue but not installed so i can do the passernger side first...
Is there a "best place" to put the jack under the tranny b4 removeing the 4 bolts?
thanx for the help
thanx for the help
yep, SLP's. passenger side is, well, super tight. Car is up as far as i can go on my 2 foot 6 tons (front and back), and to be honest, am a lil paranoid of "prying" on my tranny,,looks as if that is my only way up there.
i know, i know,,there are tons you could tell me, tons ive read (yes, a bunch of yours) but lets keep this thread on my install questions.
could i just place my jack under the brace itself?, once the 4 bolts removed, it should shift when pryed on, right?
I appreciate your wanting to let me know the bad stuff, i do, but for what i paid, im happy,,just havin one of those "not wanting to hear anything go crunch" moments, and need some help.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
WOW..... Don't they go in easier than that.?????? [was not ragging on you....Bad Blue WS6......but---you better have got them cheap..I hope.]
another way is to loosen airbox so engine will lift after you removed your engine mount bolts. of course your starter has to come out for this. either the bolts to the frame(4) on each side or the 2 long bolts that look to be easy. after they are out you can lift the engine enough to slide the header in
all went very easy after removeing the 4 tranny cross brace bolts. wedged it over (i just placed my jack under the brace itself) once that happened, the passenger side SLP header went right in!!!
i did not remove my plugs, coilpacks, etc
i did have to remove my steering linkage and oil filter,,drivers side slide in without having to move the tranny
Thanx everyone,,i will have the header install completed tomorrow, and will post up some results and pics!!!
Thanx Again!!
Thanx Again!!
Thanx Again!!
Thanx Again!!
You could wait and get a set of the NEW SLP headers.
http://www.slponline.com/coming_soon_30046_47_48.asp
1-3/4"Ceramic Coated 409 SS Mandrel Bent Long Tube Headers
New High Flow Collectors for More HP and Torque in the Mid to Upper RPM Range
Redesigned Long Tube Design allows for over 2 inches more ground clearance
Metallic Substrate 200 cell/inch High Flow Cats Included
New 3" High Flow Y Pipe Designed for Unrestricted Flow
Will Bolt to Factory Cat-Back or SLP Cat-Back
"Drop-In" Design-No Engine or Transmission movement needed for installation
No wiring needed for installation.
All Clamps/Hardware/Extensions and Instructions are included to complete the installation.
They look pretty good.
