No power steering + electric waterpump questions
Old 02-12-2008, 10:58 PM
UnZFeat'd's Avatar
Default No power steering + electric waterpump questions
Hey my SS hasnt had power steering for a while. So i have gotten used to it and dont really mind it because i do mostly freeway driving, and it looks like i am going to be getting a meziere ewp. that means i will have two pulleys that wont be running. also, does anyone have any advice for deleting power steering and the pulley belts that i will need? thanks!
Old 02-13-2008, 07:50 AM
Retired Street Racer
Matt D's Avatar
I have one small 4 rib belt going from my crank pulley to the alternator pulley. No power steering and I have the Meziere drag pump. I run a 32" belt.
If you do a search in the Drag Racing Tech section, you will see threads about how to ditch the power steering. All you have to do is remove the parts and loop the stock lines with a barbed hose and clamp it off. Then get the alternator bracket from BMR (roughly $130 or so) and you will be good to go.
Old 02-13-2008, 08:43 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
The bracket he is describing is part # AB001 and sells for $129.95 Here is a link to the page on our website...
http://www.bmrfabrication.com/misc.HTM
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 02-13-2008, 10:24 AM
Matt D's Avatar
Yep, that's it. I'm lazy and not on BMR's payroll.
Old 03-19-2008, 11:37 PM
98mysticZ's Avatar
now i have a ? can u still have a/c with this bracket is said for no power steering and a/c
"Note: this kit is designed to be used with an electric water pump and no power steering or air conditioning" and why is if for aluminum blocks only?
