corsa clone install questions
Old 02-15-2008, 10:04 PM
Twigs's Avatar
Default corsa clone install questions
I just got my LM2 and I will be putting 2.6" inlet corsa clone tips on it. I test fitted them and they fit around the pipe, but my question is, should I get them welded on or clamp them on? Also, I saw some stuff about replacing the clamps that the exhaust came with. Does anyone know about this, do they fit better or something?
Finally, which tip goes on which side? The long part goes toward the outside right?
Old 02-15-2008, 10:28 PM
Trunion King
bene's Avatar
I got mine welded. They should look like this picture.
Old 02-16-2008, 06:31 AM
98MNBZ28's Avatar
i got mine welded too,and the long side should be inside
Old 02-16-2008, 08:49 AM
HAZ-Matt's Avatar
Welded
Old 02-16-2008, 10:38 AM
agrV8dta's Avatar
Weld them on, you don't want some rippin those bad boys off!
Old 02-16-2008, 11:23 PM
Twigs's Avatar
would it be ok for me to clamp them on until I get around to welding them?
Old 02-17-2008, 12:48 AM
shoemike's Avatar
clamp them but don`t over do it.
you may want to take them off one day.
Old 02-17-2008, 01:24 AM
SweeTbone's Avatar
Weld or clamp. I would just clamp them. If you weld, make damn sure they are straight and level.
Old 02-17-2008, 03:54 AM
LS1>Imports's Avatar
when i tried to clamp my corsa clones it didnt work out that well,
it bent the back of the tips, so i got them tack welded for about $30
Old 02-17-2008, 05:17 PM
99zman's Avatar
what bent?
Old 02-17-2008, 10:47 PM
the back, 2.5 inlet starting getting crushed
Old 02-18-2008, 03:49 PM
99zman's Avatar
gotcha
Old 02-19-2008, 11:31 AM
mesospeedy's Avatar
You won't have to weld them solid, just run a short bead on each side. That will make them easier to remove if the need arises!
Old 02-19-2008, 12:11 PM
Shockwave179's Avatar
From looking at mine there doesn't seem to be enough area to clamp them at all. Joshua the guy that sells them on here always recommends welding.
