pully problem!!!
pully problem!!!
i was putting on my ud pulley, and i had to tap it on with a hammer cause the bolt wasnt cathcing and we lubed it up with oil and that didnt help much either! and we hit the outside lip of it and a peice about 2 inches long chipped off!! will this throw off the balance when i hit about 6,600 rpm's?? i also heard the ls1's are internally balanced!!??? and help would be great!!! thanks
Re: pully problem!!!
That sucks for you. I hope mine turns out OK
Use the correct tools or have a shop do it for you and your's will turn out okay.
SNAXS: Yes your pulley if toast and out of balance. You'll need to replace it and I would recommend the same as above. You never want to hammer on anything connected to the crank.
