Gauges
Old 02-17-2008, 11:34 AM
93blacktransam's Avatar
Default Gauges
ok i got a 1998 formula....... i bout 3 gauges they are boost/vacum....air/fuel.......oil psi.....the a/f gauge is rean with 1 wire tapped into my stock o2 sensor wich wire do i tap into? and also can someone help me on the oil psi i got no idea on that one th intruction suck
Old 02-17-2008, 12:04 PM
Disturbed Bird's Avatar
do you have a supercharger or a turbo? if not y would you get a boost /vacum gauge.
i cant answer your question b/c we cant see the wires or what color they are.
but when you do get it hooked up it wont be acurate you need a wideband for that
